  #52 (permalink)
Old 02-19-2010, 03:21 PM
A-Snake's Avatar
A-Snake A-Snake is offline
Original Shelby Owner
Cobra Make, Engine: CSX2321
Originally Posted by A98Coupe View Post
Hey Guys,
Thanks for all the information, but back to my original question which started this thread........nobody has posted any information about the correct stud pattern on the front cowl for a 427 (not a 289, they are different). Can anyone help?
Thanks again
Stuart
These studs as you know are only for the tonneau. Trying to use a reference point on the front cowl might be difficult.
I'd suggest that you lay the tonneau in place, locate the rear lift-a-dot snaps, then pick the 5 spaced out locations on the cowl to place the lift-a-dots studs. Then regardless of the shape of your front cowl you know it will fit.
