Old 02-19-2010, 08:27 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
I would sugguest you start with the easiest and cheapest things first. Battery connections, Chassis ground at battery, Power and ground connections at ignition box. If all these items are good, check the charging system. (Contact me if you need info how to do it) Then I would have the battery load tested (free at auto parts shop) and lastly the Ignition Switch.
So many problems like this are loose wiring, or a bad battery or cable.
SPFWiringDiagrams@Comcast.net
