Old 02-19-2010, 10:43 PM
WardL's Avatar
WardL WardL is offline
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
Depending on where you live, the transition from winter fuel to summer fuel is just starting. Vapor lock would come with a winter fuel when it is warm out or if your fuel is getting overheated in the engine compartment. You don't want to go through this every winter, so if it is vapor lock, you might look for a cooler way to route the fuel line. Is there a heat shield missing? modern day fuel injected engines don't suffer from vapor lock issues.
