Old 02-20-2010, 06:02 AM
lovehamr's Avatar
lovehamr lovehamr is offline
Stolen Avitar
Originally Posted by ken swart View Post
Get a Smith and Wesson, and invest in an action job by a revolver smith.
Have him round off and polish the front of the trigger, so you can get a smooth straight pull with the first knuckle. And don't forget your ball and dummy drills.
To each his own and every shooter has different needs but the only time that I'd have a shooter use the first knuckle, or any knuckle for that matter, is if the shooter was to weak to press the trigger with the first digit. If all of your work is up close and personal then whatever; but anything past about 5 yards, or requiring precision, should be handled by pressing the trigger directly to the rear in as straight a manner as possible. Something that is not physically possible with trigger all the way in to the first knuckle. Any time too much finger is put through the trigger guard you stand a good chance of imparting a rotational movement to the gun during the press which can result in shots pulled off center. Not to mention your own finger getting in the way of the press as it wraps around the trigger.
Steve
