Old 02-20-2010, 11:54 AM
jetsbaby's Avatar
jetsbaby jetsbaby is offline
Sounds & looks great.
Tell me what you mean by, "mid shift installed and faded by me"
Instead of buying a 350.00 dollar kit I bought the needed parts to make it myself...You really can do it yourself you just need the Tremec mid shift lug from them to make it work...A T-56 shifter turned backwards with the shift ball milled down to fit the lug...Very Easy and cheaper than buying the complete kit PLUS TKOs are notorious for leaking because of lack of sealer between the two cases..Mine would definitely leaked because of lack of sealer had I not separated it to do the mid shift install..Here are the directions from Tremec on how to do the install..Should give you an idea what you need and how to do it..
http://www.ttcautomotive.com/English...080107_133.pdf
