  #31 (permalink)
Old 02-20-2010, 04:01 PM
A-Snake's Avatar
A-Snake A-Snake is offline
Original Shelby Owner
Cobra Make, Engine: CSX2321
Originally Posted by A-Snake View Post
These studs as you know are only for the tonneau. Trying to use a reference point on the front cowl might be difficult.
I'd suggest that you lay the tonneau in place, locate the rear lift-a-dot snaps, then pick the 5 spaced out locations on the cowl to place the lift-a-dots studs. Then regardless of the shape of your front cowl you know it will fit.
Just for clarity I was not suggesting to use a tonneau with lift-a-dot snaps in place to locate all the studs. I was suggesting to fit a new tonneau to the rear studs and then use the tonneau to locate the front cowl studs. Whether you wish 4 studs as used by a 289 or 5 studs as used by a 427.
