Old 02-22-2010, 07:52 AM
ted ted is offline
If your rocker arm shafts have just the holes without any slots, you may not be getting enough oil through the rocker so the pushrod can oil depending upon how your rocker aligns with the existing oil hole. Simply grinding or cutting a diagonal across the oil holes can fix this if this is the problem.
Ted Eaton
Ted Eaton.
Fe's are fast but "Y-Blocks" are fun when they run in the 9.60's at 135 mph.
