Old 02-22-2010, 10:07 AM
timsullivan's Avatar
timsullivan timsullivan is offline
Cobra Make, Engine: Superformance SPO2820 408W; former ERA CCX 3-3408 owner
My understanding is that BAR will flunk you if you don’t have a hose running from the valve cover breather to the air cleaner assembly. You can’t run a PCV valve with a hose connection to the carb base and just a breather on the other valve cover. The breather must be closed and connected with smog hose to the air cleaner base.
