Old 02-22-2010, 04:09 PM
xlr8or's Avatar
xlr8or xlr8or is offline
Originally Posted by Got the Bug View Post
Dave,
This is something new that they've introduced in the last year or so. I'm not 100% certain, but I think their goal was to ensure that people installed the minimum smog equipment for that era of car.
There are no other smog requirements once you have secured an SB100 number, and you don't ever have to deal with any smog or safety inspections.
Yep... As of this year you must pass the visual inspection. Smoggin as a '65 you must have a type IV PCV system. That is a closed system that requires PCV on one valve cover plumbed with appropriate hose type to the carb base and a sealed Vent on the other valve cover with appropriate hose the air cleaner base.
It appears they aren't bothering with the actual smog test anymore as the tail pipe output isn't really relevent since they will never be tested again.
