  #24 (permalink)
Old 02-23-2010, 12:30 PM
ou812545's Avatar
ou812545 ou812545 is offline
Cobra Make, Engine: SPF 2168, 418, TKO 600
Neutral
Jim,
Do you know if the grinding happens when the engine is warm or cold?
My car goes into reverse smoothly when it's cold, but grinds when it's warm.
I have tried putting it into first then reverse or second then reverse. It doesn't help.
I have also tried with the car in the air to see if the wheels spin with the clutch in and the wheels don't spin.
I spent several hours at the transmission shop adjusting the clutch with no luck.
I'm ready to try UltraShift from Cobra Valley even through I don't think it will fix the problem.
If you find the problem and how to fix it please share...
