Old 02-23-2010, 01:56 PM
tkb289's Avatar
tkb289 tkb289 is offline
Originally Posted by jhv48 View Post
Well, I called the Tremec help line and the tech told me that there was no way the symptoms I have are being caused by the transmission. The input shaft has to be turning in order for reverse to grind. Putting the trans in any forward gear before reverse will stop all shafts from turning in the transmission and reverse will engage smoothly IF the clutch is fully disengaged.
Since it still grinds, it HAS to be clutch related. I'm going to replace the clutch, resurface the flywheel and then put it back together.
If it still grinds, time to disconnect the neutral safety switch and start the car with the clutch in and the gear selector in reverse.
Jim,
Interesting that Tremec says put the trans in any forward gear, before reverse ... which is what I have done with all of my stick shift cars. In my case, I usually put it in 4th gear, then into reverse (clutch fully disengaged of course). Guess it really doesn't matter, just force of habit.
Sounds like you are close to finding root cause, keep us posted.
289 FIA --- ERA 2136
Build Log:
http://www.clubcobra.com/forums/era-...build-log.html
