Old 02-24-2010, 02:52 AM
Tony Radford's Avatar
Tony Radford Tony Radford is offline
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Sounds like you don't have enough travel to fully disengage the clutch (been there). I'm running a long throw Ram and I eventually replaced my master with a longer throw unit. My suggestion is that you ajust your mechanics so that it fully disengages the clutch even if it starts slipping under load. If you can do that, you will have confirmed that you simply need more travel. It's not the easiest issue to resolve, but at least you'll know what to concentrate on.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
