Old 02-24-2010, 02:32 PM
extrememachine extrememachine is offline
Default motor problem
the first thing i'd do would be check the float bowl adjustment.
when the engine has been run, and is hot, shut it off. listen to the carb. if it's guggling, your fuel is boiling-this can normally be fixed with a spacer between the carb and manifold. do not run stock ford ignition, not powerful enough.
