Old 02-24-2010, 07:39 PM
dlotz dlotz is offline
Originally Posted by cobred View Post
That looks great, how about some dyno numbers and engine specs. Good luck.
1965 427FE standard bore
1965 forged steel cranl std/std ($ cast)
1965 Holley BC/BD
1965 MR Iron heads
1965 C5AE FOMOCO dizzy
ERSON 1.76 roller rockers
Scat H-beam rods
Diamond pistons
Comp Cams solid flat tappet cam (.571 lift / 236 duriation)
Blue thunder MR intake
Edelbrock aluminum WP
'correct' ECG-H WP Pulley
'correct' early version timing pointer
Romac balancer
1965 Autolite Alternator (rebuilt to 100 amps)
'correct' early style alternator brackets
Carter fuel pump
T-Bird puke tank
Avaid oil pan
AND NOW THE NUMBERS>>>>>>>>>>>>>>>>>
3000RPM-------419.7 tq-------239.7 hp
4800RPM-------455.2 tq-------416.0 hp
5600RPM-------416.7 tq-------444.3 hp
6000RPM-------382.9 tq-------437.5 hp
