Old 02-25-2010, 06:03 AM
767Jockey's Avatar
767Jockey 767Jockey is offline
Originally Posted by dlotz View Post
Ok, So I got the set up to finally fit, but I had to cut 5/16" off the end of the input shaft so that it wouldn't bottom out on the crank.
I then cut a 1/4" step into the pilot bushing to allow the splines that were bottoming out on the bushing to set further in. And everything fit!
This confirmed all my measurements and made sure it wasn't another issue.
Now, I am going to maching the new input shaft down to all the correct measurements so that I can put a full pilot bushing back in to replace the one I step cut.
I didn't like the idea of the spacer and my bell actually measured a depth just shy of 7" (6.950 to be exact) so I did not get a bell that was 7.050 depth as advertised.
Just another day of fabrication!
Maybe I missed something in reading the thread. The bellhousng is advertised by Quicktime as being deep enough to accomodate the longer shaft of the Tremec? And it wasn't? Why not return the bell to Quicktime for one that has the advertised specs?
