  #23 (permalink)
Old 02-26-2010, 12:02 PM
strictlypersonl strictlypersonl is offline
It's hard to tell from the picture what the rotor thickness that kit is intended for. If CCW's system only uses the 10.5" rotor, even if vented, then it's a marginal improvement.
Years ago I put together a package that used the Dynalite caliper and a 12.18" x .810" rotor (including an emergency brake). It required a custom hat and considerable machining of the stub axle bearing carrier. By the time it got done, it was probably a $1800 project. Won't have to do that again.
