Old 02-26-2010, 08:16 PM
Cobra #3170 Cobra #3170 is offline
Default Cam and Heads
Originally Posted by gsharapa View Post
Cobra #3170
Awesome Cobra and your driving ain't bad either. Are you running a solid roller cam and what heads?
Cam= solid roller 287@.050 292 @.050 .780 lift
Heads= Blue Thunder raised port CNC'd and then hand ported about 50 cfm better than my best ported Edelbrocks. The chambers are also way better than Edelbrock. The valves are relocated so that an offset rocker is needed but that helps flow.
Exhausts are 2 1/8 primarys with a 3 1/2 collector, I had to have a new stainless system fabricated because the ports are about .4" higher so we went up in primary size.
Dailey dry sump with Steffs pan and tank worth about 13 hp
