Old 02-27-2010, 03:29 PM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Originally Posted by PatBuckley View Post
I think the radiator is plugged.
I'd be leaning that way too. I had a Rod that looked fine in the top of the radiator, and I did everything ELSE to correct the problem. Since the radiator was the only thing left (pressure tested system to make sure there were no unseen leakage) I finally replaced it. I removed the side tanks for my own edification and there was at least a third and closer to a half of the lower section on both sides that was full of sediment from all the years. It would idle indefinetly without overheating, worked fine at lower speeds and around town, which is why I initially passed on it being the radiator, but once you started over the highway the temps would gradually increase to overheat. Problem disappeared immediately after. I really couldn't believe the crap in it, probably from a poor water source at some point( maybe several) over time.
WDZ
