Thread: Brake questions
Old 03-01-2010, 02:03 AM
Double Venom's Avatar
Double Venom Double Venom is offline
John,
You description feeds the physics of the master cylinder with wrong bores, OR YOUR PEDAL IS assembled in the wrong hole creating the wrong pedal ratio.
6 caliber is absolutely 'ridiculous' for these cars. If you're traveling 100 mph + to 20 mph for a hair pin turn, maybe.......
Corvette MC's 7" work well, simple two nut installation. (+/- '87 4 wheel disc). Adjust your rod length to allow less than a 1/4" movement before the piston in the MC starts to move.
Buying a full brake system is always better as a supplied kit, unless you know everything there is about a full braking system.
