Old 03-03-2010, 01:12 AM
Maurice Butler's Avatar
Maurice Butler Maurice Butler is offline
Cobra Make, Engine: Scratch build, with help
Originally Posted by Tommy View Post
A thread elsewhere on this forum is asking for help in fashioning a traction control system (TCS) for a Cobra replica with a big engine in it. It started me thinking about where I would draw the line in automating some of the functions in my car. I can see that solving the technological problems of installing a TCS in a Cobra replica would be interesting and satisfying to do. And I can see that it would likely end up in a car that was quicker off the line most of the time than I would be driving it manually. But I'm reminded of an experimental car I saw demonstrated on Top Gear. It was entirely capable of driving itself around a track at maximum speed once it had put the track layout into its GPS memory. The "driver" simply went along for the ride.
If the objective of a high performance car is to get its passengers to the destination as quickly as possible, then automating traction control, throttle control, shifting, braking, etc. seems a reasonable way to go. But if the objective is to engage the driver in ways that excite and satisfy, automation seems counterproductive. In a Cobra it would seem to serve the same purpose as engines that produce unuseable amounts of excess power. It gives the owner without driving skills something to brag about.
From years of doing factory automation - if you try and make things idiot proof you get a better class idiot. no idiot should be allowed to drive a cobra
Maurice
researching for scratch build
