Thread: ABS Power Brake
Old 03-03-2010, 03:38 PM
PurpleVenom's Avatar
PurpleVenom PurpleVenom is offline
Cobra Make, Engine: FFR MKII - 460 Crate with Cobra Jet heads, 750 Quick Fuel Carb, and Edelbrock Torker II Intake port matched to heads
I have this system and am pleased with it now that I have my leaks fixed (my fault). I also have the 10-57 with a remote reservoir. My pump motor is mounted on the frame and the reservoir is mounted with spacers, long bolts and an aluminum bracket attached to the driver's side head. All of their Master cylinder's have built in brake bias so a bias adjuster is not needed. I have had mine on the track at Gateway for RNG and have been pleased with the brakes. Little effort to brake hard, no grabbing and I had no "O Crap!" moments. They highly suggest you use Silicon DOT 5 brake fluid. That discussion apparently can go on for a long time on whether or not DOT 5 should be used on a track. I've experience no problems. I installed mine in a weekend.
Let me know if you have questions.
