Thread: Heater for FIA
Old 03-05-2010, 05:25 AM
strictlypersonl strictlypersonl is offline
You should do some serious measuring. At a minimum, you're probably going to have to modify the water inlets.
Here is our current unit. It is mounted under where the wiring harness goes through the firewall. If yours does not, you'll have to shift it toward the gauges. Not much room to go there at all.
