Old 12-25-2001, 11:07 PM
Bill E's Avatar
Bill E Bill E is offline
If you tried all the above the next step is get 12 feet of heavy chain wrap it around the hub and bolt it whit two grad 8 bolts, then tie a rope on to the axle and the other end to the chassis or the snout of the pumpkin. Make it short to limit the travel of the axle put on gloves get to the end of the chain and snap it like a whip. It WILL come out or pull the baring apart. You must than check that the axle is strata before reassembly. If you have to go to this extreme you may have more problems than you think bent axle housing maybe so check it over good. Bill E
Bill Emerson
