Old 03-08-2010, 08:13 AM
Tom Wells's Avatar
Tom Wells Tom Wells is offline
dlotz,
Stage 8 for me too if you need to lock the header bolts.
Under no circumstances should you use the ones with the little allen head screws in the center! I tried them and found out they are the same as a tap, and will tap your heads to a larger size if you ever have to remove them
Tom
