Old 03-09-2010, 10:23 AM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Making the fitting slightly larger then the hose i.d. is a good idea. On your barb... .125 high barb is ok..but make sure you take the sharp edge of the inside lip. When the hose goes over that barb and you tighten it down with a clamp you can in time cut the hose if it has to make too sharp of a bend...especialy if there is 90* corner. Just my opinoin.
" If it wont break em loose in 3rd gear, it aint enough power "
