Old 03-10-2010, 10:41 AM
Default Trans may be too low
Proibe You can raise the trans end with a spacer but you will have to off set this with changing the pinion angle of the rearend the same degree to counter the drive shaft when spinning. The hole should have only been cut after the trans was in location. Not sure about a bigger ring to cover the hole. Try to Goggle it?? Rick L.
