Old 03-12-2010, 04:48 AM
lnfletcher's Avatar
lnfletcher lnfletcher is offline
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
I suggest putting your wire through wire loom then using plastic tie wraps through a self adhesive mounting block. The wireloom will hold it all together and stiffen it so it won't drop down into view and the wire ties can be cut and re-installed when you need to "correct" something in the future.
http://www.mcmelectronics.com/produc...B-4A0-/21-2700
http://www.mcmelectronics.com/produc...=prodCrossSell
http://www.mcmelectronics.com/produc...-1505-/28-1505
