Old 03-12-2010, 05:06 PM
dcdoug's Avatar
dcdoug dcdoug is offline
By all means get the RR pan. If you track the car without it you will watch the oil pressure gauge wiggle and bury itself on '0'.
Don't know why your tray won't fit but you can modify it with a grinder to get the needed clearance. I have the same set-up with no issues.
OK, I will get the RR pan. One difference - you have an ERA and the frame cross member isn't a problem, right?
Maybe it will fit better with the different pick-up that I need for the RR pan.
www.partskeeper.com
