Old 03-14-2010, 01:27 PM
Keithc8 Keithc8 is offline
You say that he said C4 on the block and it may be D4 because there were a lot of 351W blocks cast with the D4AE on them and we have used a lot of them. Like was said earlier most all of your stuff will transfer. We can help with the heads you wanted as well as get you the right pushrods. If it does not have the lifters we can help get you the lifters with the correct valley tey that will work with the early block. We do a lot of our 408 engines with the D2 and D4 blocks. No problem with the 69 just a little shorter deck hieght.
Good luck, Keith
Keith C
