Old 03-14-2010, 06:35 PM
undy's Avatar
undy undy is offline
What brands are out there for trick, high quality motor mounts for the FE's ?
Billet or steel with vibration rubber or urethane.
They would have to be the stock height or lower.
Let's see if you can find some for us, I didn't have any luck. Our mounts cross over to a 65 to 67 Galaxie 500 with a 390. There's just no source for any performance ones. I just put another set of OEM ones on last Fall. The original were torn, melted and what wasn't torn was sagging.
You can drill them and install a couple movement limiting bolts, welding the bolts and nuts so they don't loosen up. I'm still considering boxing them in and making them solid mounts. Let me know if you find a source.
Here's a picture. I believe yours is the same as mine.
Too many toys?? never!
