Old 03-16-2010, 05:05 PM
Barry_R Barry_R is offline
few ideas
You could advance the cam a few degrees (depending on where it's installed now).
Try adding some base timing and shorten the curve to compensate - this usually improves idle and low end.
As noted a surge or lumpiness at part throttle is often a fuel curve issue that can be tuned out.
I've tried a bazillion different intake inserts, stuffers, and spacers on the dyno. Most do nothing. A very few seem to help - but they're never predictable.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
