Old 03-17-2010, 08:00 PM
patrickt patrickt is offline
Originally Posted by dcdoug View Post
Also, when I went to hook up the gauge, I noticed that the rubber cover to that front vacuum fitting was missing. I will get a replacement, but am curious as to what effect that missing cover has had? Car runs great, other than sometimes dieseling a bit when I shut it off, which is what I am trying to solve.
You mean the rubber cover where you hook the vacuum gauge and that I said was really easy to drop and lose? If you don't have the rubber cover on it you have a pretty decent manifold vacuum leak. Your car will run rough -- you absolutely, positively have to have a cap on it. A leak like that can really make a difference.
OK, so I must have been hallucinating when I told you I had a secondary metering block. I don't, mine is a standard 3310-11. Maybe too many gas fumes.
Yeah, I thought so.
Should I turn up the idle to reduce the roll while adjusting the idle mixture so it is easier to see the gauge change?
Well, you can, so long as you re-adjust your idle back down to a good number after you have your mixture right. The theory being that the very best idle mixture will give you the highest vacuum because the engine is running the most efficiently. You can monkey around with it, and if it doesn't improve, monkey with it some more. You can't really hurt anything.
