Old 03-17-2010, 08:42 PM
StanJ StanJ is offline
::: Commenting on various points in this thread...no particular order :::
Yes, the original #3310 carbs were rated at 780cfm. They had a metering block on the rear (although still a "two corner idle" carb) and were equipped with down-leg boosters. As with all #3310's, the diameter of the primary venturii was/is 1.375", while the secondary venturii measure 1.437", the throttle bore diameter of both the primary and secondary is 1.687".
As Patrick pointed out, when Detroit stopped using the #3310 and it's variants for OEM applications, Holley found it necessary to reduce production costs in order to justify keeping the #3310 in their product line at a time when nearly everyone with a race car was convinced they needed a mechanical-secondary double pumper. Also, from a simple marketing standpoint, Holley didn't really want customers who did actually need a mechanical secondary carb getting stuck on the idea that the additional 30cfm of airflow capacity of the then-780cfm #3310 over the more competition oriented #8156 double pumper trumped all other factors. The change to the more restrictive straight-leg style booster -- and the attending loss in airflow capacity -- was made for this reason. Aside from some cosmetic changes...and one major retooling of the production casting dies made in 1992...the #3310 has remained largely unchanged since then.
Unless specifically prohibited by class rules, we use a metering block on the rear of every vacuum-secondary carburetor we build for several reasons. Ease of tuning due to removable jets (and idle feed restrictions if the metering block is machined for them) is the obvious first, but also:
Compared to the current "metering plate", a metering block's ability to efficiently emulsify main-circuit fuel before it is discharged into the venturii is far better -- the average diameter of the discharged fuel droplet on the rear of a #3310 equipped with a metering block is roughly one quarter of that on a "stock" #3310.
The use of a metering block also make possible the use of a power valve in the secondary side of the carburetor. In all but the hardest-leaving drag race applications, this is a very good thing as it allows much more control of the air/fuel ratio during part throttle conditions. It is important to note here that the main bodies of "new style" (1992 and beyond) #3310's do not have a cavity in the rear metering face for the head of a power valve to reside in, and therefore require additional machining to accept this addition.
Finally, use of the proper-style metering block allows the carb to be set up as a "four corner idle" unit, with each venturi/throttle bore having it's own separate curb idle fuel circuit rather than the rear venturi having to "rob" fuel from the primary venturi idle circuits through a much-tortured (read: slow to respond) route. This is extremely important from a throttle response standpoint when you get into moderate-and-beyond performance applications, since absent a rear accelerator pump as a means of momentarily introducing additional fuel into the airstream as the secondary throttle blades open, the rate of secondary throttle opening cannot be allowed to outrun the idle/transition circuits ability to respond without causing a lean "bog". As an added benefit, this type of curb idle fuel circuitry makes it much easier to calibrate for bog-free operation that is also "sniffer friendly" at emissions test time. For me personally, 4ci on a Holley four-barrel carb is kind of like American Express -- don't leave home without it.
When properly built and calibrated, a #3310 carb makes an extremely strong and responsive carb for serious street applications.
Stan Justus
Stallion Racing Components
