Old 03-19-2010, 05:43 PM
patrickt patrickt is offline
Originally Posted by dcdoug View Post
-So I can use the method that Patrick described for lash adjustment, right?
Right.
-Any tricks for breaking the valve covers loose? I was going to first tap them a bit with a rubber mallet and then if i couldn't get them loose, to pry from the intake manifold side as gently as I can.
They will come off pretty easy -- you won't have any trouble.
-When I reinstall with new gaskets, what's the recommended silicone sealer?
You can seal your gaskets to the valve covers with some goo (I use 3m Weatherstripping to stick my rubber gaskets to the valve covers only) but you don't use anything other than maybe a little grease between the gaskets and the heads. If they leak a little bit after you've lightly torqued them down (5 to 7 ft/lbs), then you can smear a little RTV along the bottom of the covers along the gaskets.
