Old 03-20-2010, 03:04 AM
Maurice Butler's Avatar
Maurice Butler Maurice Butler is offline
Cobra Make, Engine: Scratch build, with help
usual to run a single strand around as per bottom right
for good detail on lockwiring check out the amateur aircraft web sites
Note: the wire has to be tight between bolts or the bolts will loosen until the lockwire is tight, then the bolts won't be tight enough.
Maurice
researching for scratch build
