Old 12-27-2001, 07:47 PM
Cal Metal Cal Metal is offline
Original Shelby Owner
Not just 4 bolts. The reverse gear/idler are IN the tailshaft. You will need to drive out the compression pin in the reverse shifter boss and pull it toward you to disengage the reverse rail/fork from the reverse gear. You can then remove the four bolts and pull out the tail shaft.
