Thread: Roller CAM -FE
Old 03-21-2010, 11:12 AM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
I agree with the low amount Zinc & Phosof in todays oil. Using break in lube for a new engine is essential,...... especially with flat tappet cams.
I go ahead and use this oil all the time, not just for break in.
The most important issue, CHANGE THE OIL OFTEN ,.... not just every 3,500 miles like you daily driver. If I drove mine hard, I change it, as well as when I'm driving in dusty conditions, especially with my oval cobra air cleaner sucking up the dirt directly in the hood scoop. Or when I've been on the chassis dyno.
I also agree Excaliber, using a supplement such as Lucas, STP, ext. If you don't over use these products, I don't see how it can hurt. Do they help, ???
All I know is, I haven't had any issue's with my flat tappet.
Regards,
Kevin
