Old 03-22-2010, 02:27 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Rick Parker View Post
EARL: I would be willing to bet you do not have the ignition attached to a Hot 12V switched point on the ignition switch when it is in the crank position. Check the wires coming from your ignition switch. It must get power when in the "Crank/Start" position and in the "Run" position.
I'll back you on your bet Rick.
Certainly sounds like the run position has no power while the switch is in the crank position.
Easy enough to check, disconnect the solenoid wire, put the switch in the crank position and check if 12 volts still present on the "run" wiring.
This sort of test should be done prior to firing any new engine for the first time.
Gary
