Thread: Roller CAM -FE
Old 03-22-2010, 08:13 AM
undy's Avatar
undy undy is offline
Originally Posted by Excaliber View Post
Engine builders don't like flat tappet cams for ONE simple reason, there to much work!
I Can't find the post but Keith went into great detail as to his reasoning. It was comebacks and a high rate of failure, even after the dyno controlled break-in. It's that lone reason that brought me to the hydraulic roller. Other than the parts, the labor is actually less with the hydraulic roller (no lifter/cam lube prep, no removal of inner springs on hi-lift profiles, no meticulous "on dyno' break-ins)
(and STILL requires a good break in oil)
Nope, nada, no-break-in oil requied, unless you're one of the fanatics who still subscribes to the non-detergent, single weight, break-in oils for ring seating.
Hydraulic's have their place, in Undy's car, I'm not afraid to run the real thing.
Yep, that's the perfect place. Never liked adjusting valves in the 60s and 70s, still don't like it today.
Did I mention that a 100% aluminum motor, with all the heat related material growth is much better suited to a hydraulic (flat or roller) cam anyway. There's a narrow temperature band where the SFT cam will have the "right" clearance. I sure hope I'm not starting another one of them aluminum vs iron block armchair debates
Too many toys?? never!
