Old 03-22-2010, 07:20 PM
ccx1984 ccx1984 is offline
Cobra Make, Engine: 1981 CONTEMPORY COBRA, 351C
Default crowl support
Doug did you remove your crowl support when you repainted your car. i decided to rewire and removed dash and wiring, i found that the carpet was really tight between the body and upright tubing, i would like to remove the support and remove the excess metal off the door hinge and dress up the brackets. i noticed that you filled in the hole for the steering column, how did you handle the hole, mine just looks ulgy. and last did you install that aluminum firewall and how hard was it to install.
