If you don't want the stainless, he makes the same muffler in aluminized steel for $28 if you can believe that!!! Make sure you tell him you want the straight thru glasspacks, because he makes other bullit mufflers too, and you don't want his other ones.
I told him:
Bullit: 4" od, 3" id, 30" long
Nipples: 3"id, 3" long
Total length 36" long
If you are going to weld the bullits in and not clamp them, then forget the nipples.
His number is: 602-415-9737
You will love these mufflers! They really make a Cobra sound like a Cobra. Very deep thundering sound. You can't imagine how many really smart car guys are convinced that I have a big block until I show them it's a 302. These mufflers will make your 302 sound more like a big block than a true big block does with generc sidepipes. Almost all of the manufactures use only 2" or 2 1/4" id on their sidepipe mufflers. You will have a big advantage with 3"id mufflers. The glass packing pulls out the short wave high frequency sound waves that cause a raspy exhast, leaving only the long wave low frequency sound waves for that deep sound. To gain maximum benefit, jet the carb richer to match the added exhast flow.
Ed
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
