Old 03-25-2010, 05:44 AM
undy's Avatar
undy undy is offline
Originally Posted by RICK LAKE View Post
charlandk Kevin If you are going to abuse this car a little, I think the Richmond super street is the answer. Same width as a top loader. Trans mount needs to be moved 1" back to fit. Couple of 1 gears to choise from and 2 different overdrive gears too. You can also get a custom Mustang handle to look like the orginial setup. Unless you blue print the other 2, neither would be my first choise. Remember you get what you pay for. Richmond is about $800.00 more but is better engineered trans to start. Rick L.
dunno... I had a Richmond 6 speed (same 1-5 gearsets as the 5 speed) in a 496 power 69 stingray I owned. I completely stripped all the teeth off second gear & idler on a hard 1 to 2 shift. The POS weak Dana 36 even held up where the Richmond failed. Richmond's "Super Street" 5 speed is also rated at 600 lb ft.
Too many toys?? never!
