Originally Posted by ERA Chas
builders.
You don't mention your intended usage but I doubt this will fit into any Cobra. An FE has a 10.17" deck and this is taller.
If Jon builds it, it will make all the power you can afford.
Thanks for the input. You're right. As described on the website it may be too tall to fit in my SPF. However, they can put a shorter manifold on the engine, which will allow it to fit but takes the ponies down about 30 from 760 to around 730. I guess I can live with that. (irony intended)
