Old 03-27-2010, 05:59 PM
C-man610 C-man610 is offline
Cobra Make, Engine: Venom, 302, T5
Hi Bill
Some other thoughts - check your master and slave cylnders, I BELIEVE early BDR and Venom 427 used a used Land Rover master cylinder which would fail/leak after use. BDR suggested using WilWood replacement number 260-1304 with .750 bore.
I THINK the unit fails from exhaust heat, hot fluid and seal failures. You may be experiencing this.
Also you may need to raise driver side of the car in the air to allow the fluid to fill the system.
Good Luck
My 2 Cents
