  #52 (permalink)
Old 03-28-2010, 04:42 AM
DanEC's Avatar
DanEC DanEC is offline
Something that no one has brought up is heat soaking and heat damage with a light weight steel (or cast) flywheel. I've seen a 40 lb steel flywheel eaten up with heat cracks and hot spots. It seems that using a 20 lb one would only aggrevate the situation. Aluminum would disipate heat somewhat better. Is this a valid issue or am I off base?
