Old 03-28-2010, 01:30 PM
silverline silverline is offline
Originally Posted by FUNFER2
Anyway, since I'm back from the dark side, with the ALUMINUM block. Talk to me about the parts used and the specifications or your motor.
Is there anything you would change ?
Why do you like yours so much ?
My Keith Craft 468FE is right now in progress:
Pond iron block w/ 4.25 bore
KCR 4340 forged crank w/ 4.125 stroke
KCR 4340 H-Beam rods w/ ARP2000 upgrade
Ebrock Stage-2 heads
Ebrock performer RPM intake
Comp cams solid flat tappet cam
Erson roller rockers
QFT 750 cfm mech. sec. carb without choke
Billet double roller timing set
Cometic gaskets
That 14 CUI more with 4.25 stroke would not make a big difference in HP/TQ, enough is enough. And I like the better rod/stroke ratio @ 4.125 stroke and lower piston speed. The ARP2000 upgrade rather isnīt necessary, but safe is safe and the cost not much more.
