Old 03-28-2010, 07:25 PM
dlotz dlotz is offline
Originally Posted by Excaliber View Post
Yes you do. The solenoid metal holding braket must be grounded back to the battery in some way. A starter mounted solenoid is ground through the starter itself which is already bolted to the engine. If not, then you must ground the starter to perform any testing.
Can I ground the solenoid housing to the engine block or does it have to go all the way back to the battery in the trunk?
