Old 03-28-2010, 07:52 PM
dlotz dlotz is offline
[quote=
Doltz, on that diagram the only thing I see missing is a small red wire from ignition to the MSD. You show the big red heavy wire direct to a positive battery source (the solenoid) which is good, but you also must have the little red wire that "turns on" the MSD when the key is on?.[/QUOTE]
Oops, Good catch
I actually do have he small red wire running to the IGN source. i just forgot to draw it in the diagram!
I have the engine block grounded to the chassis with a large flat 1 inch wide braided ground strap.
