Old 03-30-2010, 04:26 PM
dlotz dlotz is offline
Default ok this is wierd
So I pulled out the good ol' VM and took measurements at the Solenoid.
Solenoid ground to block has good continuity
Battery lead shows 10 Volts on Post "A", Post "B" shows zero volts
When I turn the key the "B" post to starter reads 2 Volts?
So I hooded the starter directly to the battery lead (1o volts) and I still get the faint spinning sound.
So I still have a starter problem, but now wonder if I also have a solenoid problem!
