Old 03-30-2010, 05:29 PM
Gunner's Avatar
Gunner Gunner is offline
Cobra Make, Engine: ERA 707, 446ci FE
That's an almost totally dead battery. Charge it, replace it, try borrowing the batt from your driver to check things out.
Also, check the voltage across the posts, both when it's idle and during cranking. If you show higher voltages than when checking between the + terminal and ground, you have a seriously weak ground connection.
= Si Opus Quadratum vis, angulos praecidere noli. =
